Presets: six presets per bank on footswitches 3–8, 16 own banks with colour and symbol per switch, previous/next preset by swiping, rename and save on the Nano, follows preset changes made on the pedal
FX mode: footswitches 3–7 switch Pre FX 1–2 and Post FX 1–3, tiles in the effect category colours
FX editor (long press on an FX tile): choose the model and edit every parameter live
Capture and Cab/IR: pick one of the 25 capture slots or 5 cab slots, or load any capture or IR from the Nano’s library (factory and user) into the active slot
Reverb switch (footswitch 8): toggles the reverb mix between Pos 1 and Pos 2 of the preset’s expression setting – or switches between the preset’s reverb and a second reverb with its own settings
Tuner with large note display and needle (footswitch 2)
USB audio volume of the Nano (playback from the computer), as in the official app
Footswitch learn: assign any footswitch to any function
Full-screen tiles (swipe up) for reading from a distance
Up to 8 footswitches on an SX1509 I/O expander (optional – the touch screen works on its own)
Yes, the best documentation for the footswitches is from the project from builty for the tonex pedal
You can also connect any wireless midi foot switch to the board, too, if you don’t want to solder.
Right now I’m fixing the last issues and connect the board to the desktop app, so that both connect to the Nano at the same time. It’s already working. Will do a short video later, to explain everything
