Hi there,
I just finished building a new Nano Cortex Editor for mac (others via html).
Features
- Presets: switch presets over Bluetooth (no USB cable needed), rename, save; follows preset changes made on the pedal
- Amp, gate and FX blocks: all knobs with live, lag-free updates, model selection for Pre FX 1–2 and Post FX 1–3, block colours per effect category (Quad Cortex style)
- Captures: 25 capture slots plus the capture library on the device, with a browser for categories, instruments, tags and search; load library captures into a slot
- Cab/IR: slots, level, high/low pass, mic and position; load factory or user IRs from the device library into a slot
- Tuner: note and cents display, reference pitch (400–480 Hz), mute
- Expression pedal: per-preset assignments for Gain, Bass, Mid, Treble, Level, Gate and FX amounts (min/max, invert) and bypass switching (Heel-Toe, Switch, Stop)
- MIDI controller with MIDI Learn: map knobs and buttons of any USB/Bluetooth MIDI controller to amp, FX, gate, capture and cab controls, block on/off, tuner and preset up/down; optional pickup mode (no value jumps) and Program Change → preset
- Morningstar MC6 Pro export: pick up to five presets and create a bank file: page 1 A–E recall the presets, F opens an FX page where A–E switch the five FX slots on/off. The switches are named after the effect type, use the category colours and MC6 Pro icons, and show which effects each preset uses
- Drawn, brand-free pedal pictures for every effect model (your own pictures in
img/are used when present) - Log export for troubleshooting
I hope it helps you. No USB needed!
Any Feedback is appreciated!
