Nano Cortex: Bottom Plate Screw Missing
I was packing up my NC, and I noticed that one of the bottom screws was loose and one had fallen out completely. I took a look at the one that was loose to get the Torx bit size, and then I compared it to one on my backup NC (I am the king of redundancy king). The main NC screws were a couple mm shorter that the backup NC, which is probably why fell out.
Question: Does anyone know what size screws I can use or if I can get replacements? I know that I used the Torx T6 to tighten the remaining screws.
Thanks in advance!
Welcome! Honestly, I would just email support@neuraldsp.com and inquire with them. For one they need to be aware of the issue and I would assume they would also coordinate to send you new screws (or a replacement unit).
