Multi select output routing options
Not sure if there’s a way to do this currently (if so I can’t find it) but it would be great if, when selecting the sends at the right side of a row, you could select multiple options. For example I’d like to be able to send a signal from row two in this preset to output 1 and rows 3/4. This would facilitate my WDW setup.
Alternatively, a dual detune with each detune hard panned L/R would work in this specific situation.
Two options
You can send the output of row 1 to output 1 and add a blend block with 100% mix into row 3 and 4 and select the last block of row 1 as the input.
Alternatively set the output of row 1 to output 1 and the output of row 2 (with the split you currently have) to 3/4.
Both should work
That’s the way! Thanks!
Using that concept I was able to tweak this a little and send the dry signal to Multi Out (row 2) and set the dual delay (100% mix) and the pitch detunes (100% mix) in parallel to outputs 3/4. That did what I was looking for.
So I get that full WDW (actually mix/dry/mix) experience with the dry signal going to each of my three speakers, and have the ability to mix the wet signals into the L/R speakers to taste.
@davlav This is what I was looking for when commenting on your great videos (kevinp_25).
Great! Glad the new lend was able to get you where you wanted.
Your videos got me on the right path. Your 90’s EVH preset helped convince me to get a QC. So thanks!
