I’m working on a design for a MIDI controller for Neural DSP plugins. It would be helpful if switching between the various views available in each plugin could be done via MIDI, but this is not currently available. I’m assuming this would not be difficult to implement.
What I want to do is be able to select a ‘view’ (pre effects, amps, post effects, cab sim, EQ etc,) with a suitable switch on the controller and have both the display on my PC and the function of the various physical controls on the controller change to match each other.
