Using nano cortex live
I’m considering buying a Nano Cortex to use live, but I’m unsure if it would fit in with my band.
I would use it to guarantee my tone on the rhythm guitar, but at certain points in the middle of the song, I would need to add a delay for solos, and then return to the rhythm. Is this possible with the Nano Cortex, without a midi controler?
Yes, you have access to 4 presets with the two buttons. So 4 presets is no problem, the only problem for some is, that there is a slight gap when switching presets
You must know that there is an app that only works with internet connection. If you want to change something that is only on app, you must have a good internet connecrion.
I believe you can use an expression pedal to switch on/off effects (like delay).
Check the manual section entitled ‘Expression Pedal Configuration’
