Describe your issue:
when i switch midi in an amp using the app it will not change the channel . Only when i pressing the switch does it change the channel. is there something i should be doing ?
Step 1 make a 4cm patch use midi to change amps channels
Step 2 open cortex control app switch the channel
Step 3 it will not change so press foot switch to change
I expected this to happen:
i thought like fractal i could switch using the app as my qc is away from my desk .
Hey @richierich333, this would be down to how the QC handles sending midi messages. The midi message to your amp to change setting is activated by the footswitch press rather than the scene change logic itself. Despite it being annoying, this means the behaviour is expected and not a bug, and explains why changing settings with cortex control doesn’t change your amp.
In the mean time, I’d recommend voting on one of a few midi feature requests below as this may help to lead to what you’re after if this of interest to you!
