Metering window in Cortex Control
I would love to have a separate master “metering” window available when using Cortex Control app so I could see all the input and output meters at the same time in a separate window from the editor.
Right now, I have to open the meter window, select a input or output to view, then close the window to actually make an adjustment and then go through the whole process again to see if I made the needed adjustment!
This is really slow and cumbersome! At the very least allow me to drag the current one input/output level window to the side while I make adjustments to the levels.
