Hi,
First post here.
If I use the IIC+ or the IIC++ in the plugin, is it possible to disable the poweramp section ?
Thanks.
Hi,
First post here.
Thanks.
While you can disable the cab section in the plug-in, you can’t separate the preamp from the power amp. In any amplifier, the power amp is a huge factor that defines the overall character of the sound.
Thanks for your answer.
Yes, the power section is an important part of the sound. I just wanted to use the preamp section of the IIC++ of the plugin into the return of the fx loop of my Mark IV.
Go ahead and try it to see if you like the results.
