The QC effects are great for ambient soundscapes but there still seems no way to get a decay function on LooperX. I’m still having to cart my TC Electronics DittoX4 around to play ambient stuff with decaying loops.
Surely it’s possible to update LooperX to support a decay function?
Two solutions:
- You can set a delay (and attack) value on the Freeze block, so you could incorporate that as part of your way of ending a loop
- You can control the looper parameters with an expression pedal, so can assign one EP to the loop volume and fade it out manually (is there a filter on it too, or is that just the Freeze?).
Thanks for your reply.
The decay function on the Ditto X4 fades out each overdub separately without any intervention from me. For ambient playing, I’m busy changing other effects so manually fading out with an expression pedal isn’t feasible.
I’ve emailed NDSP with a request for a decay function. I hope they take the suggestion on board.
