Hello,
When I plug my electric guitar into my Quad Cortex and play, everything sounds fine. When I click the record enable button in Logic Pro, I hear a lot of static/distortion. What am I doing wrong?
Hello,
What sample rate are you working with in Logic? (Should be 48kHz to match the QC)
You might want to adjust your buffer size
What USB channels from the QC are you recording into Logic?
You might also want to try toggling off Input Monitoring in case you’re getting a doubled signal from the QC + Logic
Consider this resolved. The issue appeared to involve the Mic Mode. Thanks!
