It would be nice to be able to load block from another preset. This will greatly simplify the creation of presets based on old ones, which will be template cells thanks to this function.
After clicking, we will see a list of presets and we will be able to select the desired. Also, somewhere in the load window, checkboxes will be required specifying the need to load all scenes or just one, and copy controller settings
I think it will be implemented thru the editor software .
What you’re describing is very similar to how you can store user’s block on Fractal editors , it saves controllers states too !
I’m confident it will be added , it’s a clever way to recall your sounds creating new presets
The kemper has this feature too, you can just store your current settings as as preset for that particular effect/amp/cab etc. and recall it at any time when selecting that effect.
