Kemper to Quad Cortex
Hi!
I’m looking at potentially ordering a Quad Cortex, which I’m hoping will replace my Kemper Stage (which I’m very happy with but am considering moving simply due to the smaller size/weight on the Quad Cortex).
Before purchasing I need to check it will do what I need it to do.
I play across 2 bands - each band has about 30 songs, and is stands I have 1x bank per each song on the Kemper, and then I use up to 5 different presets per song.
I’m very happy with my Kemper tones, and am keen not to start from scratch if moving to QC, so to save time, my intention is to ‘capture’ all of my Kemper individual presets onto the QC.
I’d hugely appreciate anyone’s advice on how best to set this up so that I can use the QC in the same way as I was for Kemper – as there appears to be a couple of options:
  1. Stomp mode.
    Would it be possible on QC to use a different bank per ‘song’ and then simply apply my different ‘captured’ Kemper sounds by assigning each capture to a different stomp pedal? This would only work for me if it was possible if every time I ‘stomp’ to a new captured sound, it can deactivate the previous stomp sound that was activated (as it won’t work if they stack on top of each other). Essentially I need to be able to switch between captures with just 1 button press - Is that possible?
  2. Scene mode
    Alternatively would I need to set up the QC in Scene mode with a bank per song, add all of my Kemper captures to the 8 blocks, and then select them/deactivate them in this mode?
Finally, I’m a little confused by the capacity of the QC. Given the number of songs I have to play across the 2 bands, am I right in thinking the best way to do this would be have 1x setlist per band, and then that will allow me to have up to 32 songs per setlist?
Really appreciate anyone’s guidance with this - thank you!
Depends what’s in your Kemper presets. If there is modulation, verb or delay then you cannot capture those sounds. You can use capture to get the dry amp sounds though. Extra effects like the mod, etc would need to be added into the QC to mimic what you’re doing with the Kemper.
Also sounds like you would want to use Scene mode on the QC. That would switch your different sounds the way you’re mentioning. Stomp mode wouldn’t really be as efficient.
Recently started using Scene mode and love it. Not to mention the routing options in the QC are way better than Kemper.
Oh right - I wasn’t aware of that with regards to modulations etc…I assumed it could capture the tone of ANY pedal - not just amp and drive tones etc? Am I incorrect?
The capture function won’t do modulation, delay, reverb, etc. It will work for preamps, power amps, amp + cabinet, drives, etc.
So if you’re happy with your Kemper, and you’re just looking for something smaller, why not go with their new KEMPER PROFILER PLAYER. I think it will load all your Kemper patches from your STAGE. I moved from Kemper to the QC years ago. And I’m way happier with the QC. But it sounds like you’re trying to make the QC be the Kemper. Which it is NOT. I’m not trying to talk you out of the QC, but it seems like you might wanna try the KEMPER PROFILER PLAYER first.
It depends!
It seems that selftitlelp is using complex presets, and the kemper player has been limited (castrated) to only a few effect blocks before and after the amp. So maybe he will not be able to transfer his presets.
Further more, the kemper player has no screen, this was a killing reason for me to not buy it.
Yep! I have decided to jump ship from Kemper, not that it doesn’t sound good, because it profiles really well, but they seem to not have any interest in a physical redesign to keep up with the times of their competitors like neural that are offering things that Kemper cant do due to its physical design.
