Last time I was using the Looper, I would have to change presets to clear the looper. Has anything changed with this yet? Or maybe I don’t know the correct solution. Thanks
Undo? that’s about it at the moment
Surely you just hit record again? After a full stop that is …
I thought undo only undid the last recording.
If you have loops already recorded and push stop, doesn’t Record just add to the others?
NOTE: My QC is up at work, so I can’t verify this. I’m just trying to plan out some new ideas for my board.
I think if you’re playing the loop, record adds a layer, if you’re stopped record is fresh.
There is no way do erase all recordings and have an empty looper. I think it is an easy feature to add, probably they just forgot to.
why do you need the looper to be empty?
If it’s stopped you’re ready for a new loop.
Or you can hit play and continue layering.
What are the benefits of having it cleared in between operations?
Not a sophisticated looper for sure, but capable enough for the basics IMO.
Probably you are right and it is just something I’m used to and I need to work in a different way.
Same here. I had time to mess with it yesterday and I think I can make the current setup work. Thanks
