Is it just me or does the Tone King Imperial CHORUS add distortion?
It seems that when I turn on the CHORUS pedal on the Tone King, it adds a distorted tone underneath. Has anyone else noticed this?
Has no one else noticed this? It really adds some discoloration to the amp tone.
I just checked it out, no tonal effect on my end.
I adjusted it to full wet and still didn’t hear any distortion.
Have you tried reinstalling it?
I made a little video toggling the Chorus on/off
I just reinstalled it and it didn’t change anything. Hmm…
I did write support as well.
huh, it does seem to drive harder doesn’t it. Weird.
What DAW is it, or is this the standalone? I’ve never tried the standalone
What else is in your chain?
It sounds the same in standalone or in Logic Prob I’m using a UA Apollo interface.
You don’t get that fuzziness though in yours?
SOLUTION: Support figured out that I had turned up my mic levels in the cab settings too much and that was causing the issue. I backed those off a good amount and am now compensating through the plugin output.
Problem solved and thank you support!
