Interface capabilities of quad cortex / MIDI keyboard?
I´m trying to plugin a keyboard to use as midi it´s an old yamaha psr E323, has 2 midi outputs, plugged them to the QC.
How can i use this or any keyboard to use a sound library on a DAW?
Can this be done through the QC or is the midi in the QC just for extra pedal controls?
It won’t work, as the Quad Cortex won’t sent the Midi signal from the ‘PIN Midi’ port (the classic ‘round’ midi cable shape) into the USB Midi signal that reach your computer …
I had to stick with my Focusrite 4i4 Gen 3 for this duty …
yes unfortunately that won’t work atm but vote this request so it might get sorted
damn that sucks, cus then i cant use the QC on the DAW with the midi which renders the QC useless as an audio interface for anything other than guitar mic setups…
i will but i don´t think it´s a feature they can implement since it probably has to do with hardware and they won´t take back all the units to alter them
MIDI is a software function so I’m fairly confident they can route what message comes from the PIN to the USB port
awesome!!! then they definitely should
