CorOS Version: 4.0.0
Describe your issue:
I always keep the input impedance set to 1MΩ, but occasionally on boot, even though the setting still shows 1MΩ, the input level is clearly lower and the behavior is consistent with a low-impedance state.
Changing the impedance to a different value once and then setting it back to 1MΩ immediately resolves the issue.
A reboot also resolves the issue.
This behavior seems to occur primarily on a cold start, such as the first power-on after the unit has not been used for an extended period of time.
