I bought a Quad!
Hi guys,
I bought a Quad cortex. currently i will connect it to a single yamaha HS-7 (for home use exclusively) …will it hinder the sound quality ?
thanks in advance for your reply,
Maor
Will it allow me to mess with IR too ?
Congratulations and welcome to the QC forum!
Yes obviously. Use the IR loader block after an amp or amp capture DI.
I have HS7s and it works fine although you should consider getting an FRFR, to me it goes some way to being similar to using a normal cab.
ARRIVED !!
So, first question already :frowning:
what the optimal config of the HS-7s to work as best as it can with the quad, please ?
Thank you in advance,
Maor
