In order to connect the FCB1010 to your computer, you’ll need either an audio interface with 5-pin MIDI functionality (like the Focusrite Scarlett line or Universal Audio Volt line) or a standalone MIDI-to-USB interface. The FCB1010 doesn’t have USB connectivity built in. If going the audio interface route, you’ll only need one USB port on your computer. If going the MIDI-to-USB route in conjunction with the iRig, you’ll need a USB port for each.
@Bando Thank you. I never did it so I was ensure about physical devices connection. It’s working.
I’ve used MIDI-to-USB path over WIDI Jack instead of physical cable (Bluetooth MIDI). It’s working properly. I can’t hear any delay even with expression pedals.
