How do I easily move a Logic Project with 20+ guitars on Rabea plugin to Rabea X?
I have upgraded a bunch on plugins but have older logic pro sessions. I never saved presets. I just tweaked plugins to taste. Now I have 20+ plugins in each logic project in non-X versions of the plugin and I want to easily move them to the X version with the same sounds. I upgraded Rabea and a bunch of others so it’s a big job and I did it manually for one plugin and it was a pain in arse having to save a preset and then figure out which folder it saved to and then manually select through on the new X plugin to load it. Just hoping someone else has figured out a better way
You should be able to multi-select all the guitar tracks and change the plugin for all of them at once.
