Hard panning L/R into looper
New to the QC. What I am trying to figure out is the easiest way (or perhaps the way with the least amount of foot tapping) to record a loop hard panned left, and then record an overdub hard panned right. I would then solo/sing with pan centered.
Appreciate any advice !
Add a Gain Utility before the Looper, and make sure the Looper is set to source from the grid.
You can then use scenes/expression pedal to change the pan in the Gain block, and bypass when you don’t want it.
Exactly what I was looking for, thank you so much!
