Global EQ problems
CorOS Version: 2.0
Can’t use the new global EQ, it displays a warning that because of cpu usage the global eq is unavailable. CPU monitor says 26%. But, if I insert a splitter with nothing in between the cpu usage goes up to 27% but now I can suddenly use the global eq.
The Global EQ works on the first two DSP cores therefore you need to utilize your rows as needed to distribute the DSP load. Looking at your example, there are ways to reduce DSP usage like removing the gate in the first block and taking advantage of the built in gate by long pressing the input for that row. lastly, take advantage of the other cores by distributing your load across all cores using splitters/mixers and related.
