I’m working on making a full stereo preset for my Quad Cortex but am running into issues with CPU capacity. My plan is to run my Strymon Compadre compressor into my Eventide H90’s input 1, then the H90’s outputs 1&2 into inputs 1&2 of the Quad Cortex, split into two lanes with the a Myth Drive into a volume pedal block into Dumble ODS’s into a pair of cabs then have that go to a dry path out to outs 1&2 with a wet path with a delay block and a stereo effects loop block for my H90’s second algorithm for verbs. Even though my CPU usage is only at 48%, it’s still disabling the input gate and global EQ. Any tips or workarounds?? See the pic below for my signal path.
Move row 2 items into row 3. I think they split the CPU between 1/2 and 3/4, so 48% almost all on 1/2 may be hitting the limit.
yeah, the gate and EQ are tied to Rows 1 and 2, you need to move some stuff off of there and onto 3 or 4 to lighten the load and then the Global EQ and Input Gate will kick back on, as h2loh recommends
