I am not sure if anyone else had the same experience as I did. Seems when I step on the switch or press the switch a little too hard with my foot, the unit bypass itself for a second. The level of the bypass unit is quite loud and very noticeable. I have to be really precise and a little gentle with it for it to function properly/normal. Can this be fix?
Other then this, I love the sound I’m getting from this little guy. The Nano Cortex sounds amazing!
Which switch are you referring to? Are you by chance disabling the preset in any way? I haven’t heard about any foot switch malfunctions but worst case I would email support@neuraldsp.com so they can get you sorted.
Only two switches/buttons on the unit, to switch between Green to Purple Preset. Both switches on mine seems to react the same way. Like i said, if I lightly press the button, they work fine… I guess mine is the only unit doing this.
