I would like to step onto my expression pedal with a toe switch and trigger a scene as well as turn on the wah simultaneously. Is this possible? Currently I have to step onto the scene block and then step on the wah to activate it.
For the XP Toe Switch to trigger a Scene, you’d have to use the midi-jumper hack.
If you set that up, you could assign the wah to turn on when the scene is selected and select that scene via the toe-switch
Another way to do a one-press for this (without the hack) would be to assign the wah bypass to the Scene switch
Thank you! I will try both.
I tried the midi jumper hack and it all worked. Now I step on my wah and it turns on the wah, adds gain and a bit of delay all by triggering a scene. It’s fantastic. Thanks!
awesome! That hack really opens a lot of possibilities. I’ve been using it to open Presets in Gig View, but now I don’t have to anymore (after the last update) so I’m not sure what I’m going to assign it to.
Glad that worked for you!
