Enable multiple input tuner also for return 1 & 2
If you use several instruments on the QC, it can be very annoying to change the input of the tuner. I regularly have 4 instruments plugged into the inputs 1&2 as well as returns 1&2.
You can have the tuner set to listen to input 1 and 2 and to mute them at the same time. But return 1 and 2 can only be selected individually.
I request a feature where the tuner can be active on all inputs at the same time, namely on input 1, Input 2, return 1 and return 2.
It would also be useful to mute return 1&2 together (like for input 1&2). For example, I use a guitar with two outputs connected to return 1&2 with my vocal mic attached to input 1.
This would be especially useful now with the qc mini - I have my Godin A6 guitar set up so that the acoustic output goes to input 1 and the electric output goes to return 1/2. (I have my vocal mic going into input 2).
I’d like to be able to either select which inputs to use as an input into the tuner (for me input 1 and return 1/2) and which inputs to mute while tuning (could be just input 1 and return 1/2 or all inputs)
At the moment I have to set the tuner to input 1 and make sure my acoustic volume is up and my electric volume is set to zero.
apparently this is not a very popular need…but the ones who need it really need it…
I hope this is getting more popular, since I would believe this is an easy implementation.
It would be great if this can be saved by preset
Maybe this can become a quality of life update? :slight_smile:
