Tuner Input saved to each preset
The Tuner Input Assignment shut not necessarely be global. I use one preset for electric (Input 1), one for acoustic (Input 2) and one for steel guitar (rtrn1). I want to set the tuner for the used input for each preset. There should also be an option to chose multiple inputs for the tuner (i.g. if you use one preset for both acoustic (in2) and steel guitar (rtrn2).
Yes!! I agree, would be perfect! :relieved::pray:t3:
Yes I totally agree, please add this feature.
This already exists If I understood the request correctly.
There’s an option “Input 1/Input 2” on the tuner screen for “Input”.
The request is for each preset to save a pre-determined tuner input for that particular preset. Tuner inputs are global currently so uses the last used tuner input.
Oh right, I misread sorry!
YES!!!
I have the same problem, using inputs 1/2 for two diferent guitars and RET 1 for an acoustic, I just can’t tune the acoustic in a live show. Maybe just put the option for all the inputs. But will be perfect with the preset thing on the tuner inputs
Yes! We need exactly this, it is a bit frustrating on gigs when using several instruments that we have to manually change with input is active for the tuner. As Petter is saying here we should hav the option that the tuner follows the input/s of the preset.
Or maybe just be able to create a user customizable “instrument list” and store your custom tuner in presets under that instrument list with any user offsets
Another posibility would be to have the 4 pedals in the bottom row associated to each one of the 4 inputs, that way you could select the current active input with your feet.
Since those buttons are not in use during tuner mode, that would work, I guess…
Makes sense?
Another interesting option would be to hae the tuner as a normal device that you can just add to your fx chain and have it work with whatever input as per your grid arrangement.
