If you have a ducking parameter, particularly on your verbs and delays, you don’t need to set up scenes as much as your playing dictates how much ambience you’ll have. Let chords ring or play staccato and get more ambience. Strum out and the echos diminish some depending on the setting. Coming from the KPA, this is one feature I really miss as it really saved from having to do a lot of tap dancing, one delay setting was much more versatile for different parts of songs and allowed more spontaneity in my playing style. I don’t think it would require a ton of DSP if KPA does it.
*To be clear, I propose this as a parameter on ALL the algorithms in these categories (like the KPA does) rather than a limited a dedicated ducking delay algorithm.
Please use the search prior to posting new feature requests. This requests already exists:
