It would be very usefull to have the possibility to choose wich type of capture the user is going to make:
- full amp capture
- NoCab capture
- drive capture
Each mode should be linked to a dedicated template/patch, with the capability for the user to put effects blocks or cab. In this way, at the end of the capture process, the user can listen and compare the real thing vs. the capture inside this template patch.
Agree need to be fixed
