Default folder - return to folder used last
If I open the Favorites folder, select a preset and play…then want to continue selecting from that folder… I tap the preset name to get back to folders but it defaults to ‘My Presets’.
That would be what I’d expect if I had just chosen a preset from ‘My Presets’ folder but it should default back to which ever location I was in last…in this case the ‘Favorites’ folder.
I realize this is a small thing to fix but it is the most frequent thing that impedes progress for me. If you feel the same please vote it up…or if I’m missing some way to solve this let me know
Thanks
The current behavior is incredibly annoying.
Obviously, I am favoriting things so that I have easy access. It’s quite hard to easily switch between favorited presets based on the way things currently work.
Current behavior
1 go to presets/captures screen
2 note that factory presets is selected
3 nav to favorites
4 select a favorited preset
5 nav back to presets/captures screen
6 note that factory presets is selected
7 nav back to favorites
8 select yet another favorited preset
Expected behavior
2 whatever was last selected should be selected (in my case that would always be favorites)
3 select a favorited preset
4 nav back to presets/captures screen (to switch presets)
5 note that favorites is selected
6 select yet another favorited preset
Ideally the up/down nav would also work if in the ‘favorited presets’ but that’s another request.
Please fix this Neural. The current UX pattern is painful to use.
Video of current experience here:
