crying clyde wah bug
I am having an issue with the crying clyde wah. It seems that anytime I assign it to my expression pedal. It will work fine until I change the preset and go back to it then the expression pedal longer can activate the wah.
I have assigned the wall to expression pedal one and have assigned the bypass switch-on to the"heel toe" of expression 1 .
each time I change the preset, I have to go in and reassign the expression pedal. This only seems to happen with the Crying Clyde wah. I have tried it with the other wall, pedals and don’t have this issue. Has anybody else experienced this with the Clyde wah?
I was fighting with this same thing yesterday and thought I must be doing something wrong.
I just changed it to the regular Crying Wah and it works as you’d expect.
Ryan
Hey @dtank5992 , sorry to hear about your issue. Please email support@neuraldsp.com as this appears to be a bug they can resolve etc. Thanks!
I just submitted a similar bug which I think only happened when I started using the Crying Wah.
Update, this does not happen with the Bad Horsie Wah.
I have the same issue. This is sooooo anoying, so I really hope that they will prioritise this, at it imo makes the entire wah function absoluttely useless, as you would have to go into the settings to make this work between each song :frowning:
Since this thread is a year old, I would suggest emailing support@neuraldsp.com so they can log your issue and get you resolved.
