After the update I picked the PLINI X and tried to edit my main preset for stage with Plini amps instead of my previous amp captures.
The thing is I aim to make a full preset with possibilities, therefore I added 3 amps and 1 cab of Plini in the very same preset. It ended up with a high CPU level like 85% and disabled the input gate and global eq. I can live without the input gate and global eq, that’s ok.
What I’m scared of is if using QC with such high CPU level is dangerous in long-terms? Or it has nothing to do with any kinds of failures? Eventually the CPU limitation, disabling gate and eq and not allowing any more blocks are kinds of securities for the unit, right? So that must mean it’s safe to use in that way imo.
QC manual says it’s ok to use CPU up to 90% and with some disabled functions. But using the unit at the edges made me a bit nervous for long-terms. I play with it twice a week on stage, so that would be a disaster to face any failures.
Please let me know your thoughts, knowledge and experiences.
Best regards
Özgün
