Avelon
September 10, 2025, 12:26am
1
Hey,
the new Quad Cortex should be shipping now. Did you receive yours?
So many questions…
What are the main hardware and software differences between the old and new one?
Are there pictures were the inside of the old and the new Quad Cortex is compared?
I heard the new Quad Cortex will have less power consumption? How much?
Will it have a better WiFi antenna?
Will it be lighter?
Well, hopefully. WiFi on the original was terrible.
Neural already explained the differences. The units are identical from a user perspective except for the a new audio codec from ESS and an associated setting.
The wifi on the new units is definitely better for one thing
RN69
September 17, 2025, 7:36am
5
I think I will buy the new QC with new ESS codec at the end of this year (if I can get one), so I might take some photos or make a short clip.
Also, I’m using PD charger to power the QC, I will see how much current it consumes.
Old QC consumes up to about 24W(12V2.0A) in the boot, 18W(12V1.5A) in a stable state, which varies slightly depending on the display brightness.
aoloso
September 17, 2025, 8:05am
6
Also i’ve heard on the new one every plugin on the market is available straight away and the QC makes excellent coffee with just one button push!
In what evidence do you base your statement?
Dicko
September 17, 2025, 10:41am
8
How annoying I’ve just bought one in the UK and I bet it’s an old one.
Doesn’t matter. From a users perspective everything will be the same.
Dicko
September 18, 2025, 6:16am
10
OK Thanks, i was a bit worried there.
MP_Mod
September 20, 2025, 9:13pm
11
Agreed, I haven’t heard anything about the wifi module being changed, updated and or modified in any way from support.
I bought a 2023 and 2025 QC, and their internals are quite different.
I asked NDSP about it, they said its still the same sound but personally i felt 2023 analog converters are more warm. i did an A/B comparison for XLR out and USB
for USB its 1-1 identical
but for XLR out, 2023 was warmer somehow.
posted about it here: https://www.instagram.com/p/DLpKkVxRLeY/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
Then I’m glad I have the older ones.
Avelon
October 8, 2025, 6:14am
14
Very interesting pictures! Thank you for sharing this.
Where can we see and hear the A & B comparison ?
I did not have the time to edit but I do have footages. Ill try to edit and post a quick youtube AB test over the weekend
Meanwhile here are raw audio
Old qc https://drive.google.com/file/d/19mAuxuZ9UbMRHchmSKShVzTlHo7KO-gL/view?usp=drivesdk
New qc https://drive.google.com/file/d/1Nvmeyze8DnslUJ6DjBhO5q5pPNkn1yj7/view?usp=drivesdk
Null test video showing low end rumble means old qc diffs on low end
Forgot what patch i used but its just an amp with a cab no other fx
So does the older unit have the more pronounced low end?
Yes I believe so as per my investigation
thank you for confirming.
unifyx
January 23, 2026, 11:32pm
19
the thing is, that both internals of the qc you posted, have still the old audio chip.
I have the newer one but still on the cirrus chip.
ESS should be the same like the new just with the ESS chip in the same place as the cirrus was.
Hmm… Isn’t the ESS chip doing both ADC and DAC, whereas the Cirrus Logic chip setup needed two separate chips (one for ADC and another for DAC)?
