Hi,
I am trying to capture some pedals but having issues with clipping and get a warning during the Sanity Check phase of the capture even when the pedal is bypassed.
I have set both In 1 Level and In 2 Level at 0. If I lower the In 2 Level by -1dB I don’t get the warning, but why would I need to do that? It seems to suggest that gain is being added to the signal somewhere in the QC? To further test this I connected a cable directly from Capture Out to Input 2 during the capture and I get the same issue – clipping warning during Sanity Check.
I’ve had this happen for sure. Sidenote- the effects loop in the QC boosts the signal about 4db, so I have to lower the effects loop block by that whenever I’m using it.
I wouldn’t be surprised if there is a slight boost happening in the capture process. It’s possible some of the signals the QC sends have a little more output, esp if they’re a lower register. But I would just adjust the level slightly so the signal doesn’t clip. Esp if you’re just adjusting it by a db.
