CorOS Version: 2.2.2
Describe your issue:
When changing microphone type/IR in Cortex Control, nothing happens. Until I open the CAB block on the physical device, then the new mic type/IR change is applied.
- Open Cortex Control
- Navigate to any preset with a cab in it
- Open the cab block settings
- Change mic/IR
Nothing happens.
I expected this to happen:
When I change the mic/IR I in Cortex Control I expect to hear the newly selected mic/IR.
- Opening the CAB block on the physical device resolves the issue
- A nice way to experiment is: select 2 identical mics but put one in inverted phase. You should hear nothing if the 2 mics are selected and all other settings are identical. This is NOT the case until I open the CAB block settings on the device itself.
