CorOS Version: 3.0.0
Describe your issue:
I made a bunch of folders and subfolders to organize my neural captures section. Using Cortex Control, I made 7 folders, some of them with subfolders. 20 Folders and subfolders in total.
When using Cortex Control, when adding blocks, I can see them and navigate through them fine.
When trying to add a capture block in the the quad cortex, I can see the main folders, but when I tap to enter and see the subfolders, some of them appear empty, when they shouldn’t be.
And I think I found the reason while writing this report:
If I have to scroll down to select a folder (let’s say 1 line of text), then the subfolders section will be scrolled down too.
So if I have to scroll down 4 lines of text, and the folder I tap has only 2 subfolders in it, I won’t be able to see them, and I can’t scroll up or down to show them.
- Make 8 folders in the Captures section
- Make 2 subfolders in the last of those folders
- Try to add a block from one of those 2 subfolders, you won’t be able to see them.
I expected this to happen:
See the subfolders.
I’ve tried making folders and subfolders to see why that happens, and reached to the conclussion I have explained.
I also tried the same thing with the IRs, and when selecting an IR from the IR block folders and subfolders work just fine.
