As the title says, can you re-order setlist (change the number of them) in the Directory?
Would love to give this another push to the top. It’s a bit of a pain in the ass to not be able to move whole setlists around! Also, if we could upload a whole setlist to the cloud and download it in one move that would also be amazing. Or even have a way to locally just back up a single setlist and then use the desktop editor to file Setlists that we can load individually to the QCs themselves. I’ve got multiple units, and this would make it so much easier for me to work with them when I’m prepping them for gigs.
You can move presets around and swap them. Unfortunately can’t insert one between two presets, so you need to shuffle things around to re-order a setlist.
This request would make things a lot better if implemented.
While we wait for this feature, I’ve had some success using a smart phone with a setlist manager app connected via usb to the QC. I can recommend Songbook Pro. No frills, Does the job.
That’s a fair shout, actually - I use Stage Traxx 3, and the app selects the correct QC presets for whichever backing track I’m using, via a Widi dongle (ie bluetooth midi). Works brilliantly.
Which midi dongle are you using? Trying to figure out whether I should get a self powered one or does the QC power the Bluetooth midi device?
Yes, the QC can power a WIDI Flex dongle; it take the power from the 5 pin MIDI out.
This is the dongle I have: Nektar WIDIFLEX Wireless Bluetooth MIDI Interface : Amazon.co.uk: Musical Instruments & DJ
I have put together a video on YT showing how to make it all work: (this is Part 1, there is a Part 2 as well)
Hope that helps
That is incorrect, the QC will power a WIDI dongle from it’s 5 pin MIDI out…
