FOR LIVE USE! I would like to mix the 2 products on 3 different scenes calling up 3 different Petrucci (or Gojira, etc.) presets. I have the Petrucci in the layout of the Fractal preset but don’t know what CC numbers correspond to each preset. I do not know how to do MIDI Learn or anything MIDI for that matter…
Check the fractal manual. I think there might be a way to access this. I am also wondering if you have the plug-in imbedded in the AX preset as a block can’t you just go into AX Edit and assign it to a switch? Or assign it on in a scene and off in another? I do the reverse with The HX stomp in the EL of the quad and then I can assign it to the Quad foot switch.
