Hello, I’m a new owner of the QC.
Can I use my Way Crybaby 95Q and a Ernie ball JR VP Tuner (as a volume pedal).
And, please, if can use them, how plug them (which inserts) ?
Many thanks.
Aymeric
Many thanks.
Aymeric
Yes, you can use them both with the QC.
Your best bet would be to place both of them in front of the QC.
I use my 95Q in front of my QC. Works great!
Thanks for your answer.
I put the CB in front of the CQ. For the solo, I put a block with equalizer for boost.
I put the CB in front of the CQ. Perfect !
I’ve used a vp jr for a while before moving on but if I was you I would use the vp as expression, so it can be volume or anything else(and movable in the chain)! just connect a trs Y cable to the expression port and the ring and tip ends to the vps in and out and voila!
