Cab in the room emulations
Something like the line 6 powercab do.
Or something like the kemper kabinet (kone).
What I’m looking for, is cab emulations base on different populare cab/speaker combination, but without the mic, the preamp or else…
So that when you run it into a FRFR, it sound as close as possible to a real cab…with only the FRFR coloration (because we all know that all FRFR are not equals).
Use case exemple : rehearshal
This in combinaison with the pickup emulations I suggested will open a world of possibility.
Think about this, the abelity to change your intired gear by the push a single button
How would it be that different from how the current system works with the cab block? You basically want the mic out of the picture, but in practice it would mean using some sort of a measuring mic instead which is very flat and has no colour. Do you know why no one uses those in recording? Because they sound very bad.
I’m bupping this old suggestion, cause i still think it would be use full for reashall.
Just get the john mayer plugin, the cabs included have a room mic that you can blend in to max and its very much like pkayin in the room if you’re using inears even. Just get the free 14 day trial and try it, i don’t see neuraldsp doing what you’re asking for.
Maybe they could add something like the Amp Tone knob on the Tonex Cab, which makes the simulated cab sound more like a studio recording or more like an amp in the room.
I never heard it but people say it is very convincing.
Don’t know if it can be done without more precise knowledge and control of the real speaker being used (the description talks about high frequencies dispersion) or if it can be simulated in the QC, but it would be nice.
I’m not sure how you could truly do this. You can measure the frequency response of the mic and other devices in the signal chain (that were used to create the model) and apply a countering response curve but how do you compensate for mic position, proximity effect, room response (in the spot where the speaker was sampled) phase cancelation, etc. Microphones just “hear” differently from human ears.
So just add a room reverb, and adjust the blend. It isn’t doing anything other than that.
