Seems like there are 3 types of captures for this amp:
- Preamp only (labeled as “Ch1, Ch2, and Ch3”)
- Power amp only (labeled as “OLD,” “NEW,” “VAR,” etc.)
- Pre + Power (labeled as “Ch1, Ch2, and Ch3”)
I have two questions:
- For the Pre + Power captures, based solely on the naming, I assume that the power amp settings are static throughout these captures and the only thing that changes is the preamp channel/settings? If so, does anyone know what the power amp settings are for these captures?
- I had assumed that since 1 is preamp only and 2 is power amp only, then having two blocks for 1 running into 2 would result in a complete amp, similar to (3) the pre + power captures, but with more tweakability… however, this sounds like garbage, so I am second guessing if that is how it works. The pre-only and power-only honestly sound great on their own, but the moment I run a pre-only into a power-only, it sounds so bad that I can only assume that is not how this works.
