Hi
I setup Logic Pro wih this:
What input I’m supposed to chose :
The USB setup is:
And the pret setup is:
Hi
The USB setup is:
Are you having issues or just showing how you use with Logic?
Hi,
Sorry for the confusion here.
I’m having issue : I have no sound that come in Logic Pro.
Or, to be more precise, I just have a sound in the right channel that sound low and dry, as if the sound was not processed by the signal chain.
Thanks
Try choosing input 3/4 on the Logic track. Or make it a mono track and select input 3 (if you’re plugged into QC input 1 with your instrument)
1/2 are DI only, no fx.
Thank you! And also need to set the output of my preset to multi out
