Use Plug as insert VST, make some regualtion in partvolume in Cubase for dynamic adapting solo guitar. The Plug seems to ignore volume regulations on the part completely, but if I turn it down nearly to zero ∞ , there is some little reaction. So the range in the signalchain seems to be corrupted through the Plugin. Testet with other plugs, no problem only with Archetype RabeaX. Some Hint or tip would be great! Thanks folks
