Archetype Mateus Asato Transpose sounds awful
I need the transpose function in the Archetype Mateus Asato plugin when gigging live. It sounds terrible especially with clean tones, like its breaking up (and not in a naturally sounding way). This is not related to acoustic sounds bleeding into the mix. I have double checked with headphones. I tried removing all other FX and even rebooted the Mac with no other apps active thinking that it might be a memory problem. Has anybody else come across this issue?
Is the system on battery power or a charger when this happens?
The Macbook Pro is on battery power. I use a Scarlett Solo as a DAC, connected via a USB-C port.
I have tried this at home, while on a charger and same thing happens.
