Hi there,
I wanted to install standalone version of Archetype Gojira on windows 10, but I get this error:
“Error reading from file …\Archetype Gojira.msi Verify that the file exists and that you can access to it.”
I can"t repaire or remove the plug in.
Please, how can I solve this?
Hey @fabienj. That seems to be a common error message on Windows systems related to the security settings.
Please check if this solves your problem: Why do I get an "Error reading from file" error when trying to install? - Mythicsoft Q&A
It doesn’t solve my problem, I’ve checked all athorization, it’s all good for me, but the".msi" still missing
Problem solved! I try to explain, but sorry for my english.
I just open the Gojira.exe, then i open the file gojira.msi. I get the error “Don’t find the .msi file, please inser the Disk1 Archetype Gojira” so i change the path from Disk1 to the gojira.msi.
It open the install file, and i remove gojira from my computer.
Then i restart my computer, i open Gojira.Exe and problem solved, i can do everything!
Thank you
I found a solution easy going with a tool to resolve the problems…i didn’t have the msi anymore…and i couldn’t remove the older version of Cory Wong… i used this and it worked Fix problems that block programs from being installed or removed
