Hi. Does anyone have the grunge presets in this video? The link they provided no longer works.
Fuzzboom.xml (5.6 KB)
I donāt normally play with fuzz but this one is too much fun.
I donāt know if youāve checked again since you originally posted this, but the link worked for me just now.
Hi there⦠Did anyone make some Dimebag tones with this one?
Thanks in advance.
Anyone captured decent metallica tone on this that they can share ?
I tried to get close to Metallicaās current tone, which over the years has pushed more towards single note clarity over sheer heaviness. I quite like it, thereās a real beef and chainsaw quality to some of the riffs on 72 Seasons, although the discussion seems to fly over many YouTube commentersā heads. Chugging on this present wonāt be crushing, but it will be tight (and it loves an F# powerchord, believe me)
72 Seasons.xml (5.6 KB)
Hi, I made a preset for something like a late DTās distortion. Iād like to share it with you, in case Iām open to some advices to make it better. I hope youāll like it. Cheers!
Prog-jira.xml (6.0 KB)
I got the presets but i would like to know something.
The presents are named:
- 1(m1)
- 2(m2)
- 3(m3)
- 4(m4)
and so one, what tunings are these?
I have almost a perfect sound for The Smashing Pumpkins - Mellon Collie and the Infinite Sadness album, as well as Alice in Chains - Dirt Album, and Social Distortions self titled Album here are the tones. GrungePresetPack.zip - Google Drive
Not sure if this belongs here. Please point me in the right direction if not (I also plan to cross-post on discord).
Is there any way to use MIDI to control the TAP TEMPO in the delay pedal?
The TAP stomp switch doesnāt seem to have a MIDI map available. The available controls in the plugin appear to the tempo itself, which could be controlled by a CC, but I want to use the ātapā function on my pedalboard.
It supposedly can be synced to the the DAW tempo, but thatās not what I want, because that affects the recording itself. I just want to be able to tap the tempo into the pedal.
It doesnāt even have to be MIDI, I could make my MIDI pedalboard send a keyboard press, for example. But I think the root of the issue is that the TAP stomp switch doesnāt seem to be linkable to any controls at all.
A workaround could be to use a CC pedal to control the TIME knob, or the TAP TEMPO setting as I mentioned above. But thatās not really what Iām looking to do.
Thanks!
Not sure if this is for this thread but Iām kinda troubled lately by this issue Iām having and any help would be much apricated. So, I tried to make a preset for a song Iām covering (well actually i used an already existing preset and just altered it a bit) and when I tried to save said preset I always get the same message:
I did everything that the message suggest and yet the issue was not solved. If anyone has any tip on this please lend me a hand. Thanks in advance.
Hi, I have downloaded this preset but how does it work? Have I to put in the user folder and use as normal preset? And, if I use and then I want to save my settings, will the preset remain in the new file?
Any kind soul was able to make a preset similar-ish to Deftones?
Looking for a Melodic Black preset such as Dissection. Anyone got a preset?
thanks, iām going to try these out! I came here specifically for MCIS and AIC
Clean Rvb Mirth.xml (3.7 KB)
CLEAN TONE, enjoy! Finding it very versatile. You decide if you want to turn on the gate or doubler.
Prepped for a Reverend Z-One neck or middle position pickup.
Let me know if anyone finds it useful
When can I upload my own tones to this thread?
