Hi, I was wondering if any type of synth blocks or synth effects were in the works for Cortex?
Similar to those found in the Fractal Axe Fx.
I really like the ablility to add a synth drone in the background and play over it with a standard guitar tone.
I use a exp pedal to control the mix and volume of each and also have the ability to change the drone notes as well.
I’m really interested in this also. Using the N-DSP as a high-end Zoia would be awesome especially given it has MIDI. If you look at the promotional images it seems there is a synth block:
If you can play synths by MIDI it would be awesome since I’ve been toying with the ideia of also having some keyboards on my live setup and not just bass
Polyphonic pitch to MIDI is asking a lot. 4C might have a potent CPU as modelers go but it still might not be enough for pitch to MIDI along with a typical guitar processing chain.
Not sure if tat is what I was looking for. Please let me explain.
On the Axe fx ultra- 2 and 3. I was able to add a “synth block” on a separate signal path and create a synth drone with a volume pedal.
Second example : Iwas able to trigger a synth sound playing the guitar. Like a pad type or string sound.
You could do both of these things all the way back to Axe FX ultra.
I can not imagine with the DSP amount of this unit. This is impossible.
I also can’t imagine more poeple wanting this. To add like a POG effect to their sound.
Not using midi on Fractal, it’s a EFX Block using the same guitar tone detection as the Pitch Shifter. The quality of this effects also depends on how accurate and quick the detector is, I hope for a good one in the QC. In the AXE II it is rather mediocre, I would say. Much better in the AXE III.
In my last post I wrote a thing wrong, I have an AXE-FX II.
I would welcome a Synth block too… It obviously would be mono and a bit limited, But still nice to have, I use the Fractal Synth block all the tine for the old Violin patch …
Didn’t love the mono synths on the AxeFx and Helix (though the Fractal violin preset is pretty cool). There’s a reason why my Quad Cortex board is gonna have a SY-1 (or maybe even SY-300 if I decide to upsize) on it.
I seriously thought about selling the 300 getting the 1000 but I’ve been spending a good bit of money on another hobby and I’m probably not putting a 13-pin setup on any of my Strandbergs.
A synth block would be very useful (polyphonic better).
The little Boss Sy-1 can do the job, why not this mega-powered QC ?
Even if there is only the remaining DSP power for a simple ‘classic’ chain : dist/amp/delay/verb !
