Amp Capture only Capturing Raw Signal
I tried to capture my Friedman JEL50 running into my Two Notes Captor Reactive Load. I connected all the cables as the manual dictates. When I do the capture, I don’t get any errors. However, when I listen to the capture it is just a raw guitar signal, no amp sound. Any ideas what I may be doing wrong. I was able to capture a preamp pedal I have just fine. TIA.
Are you wiring everything like this?
Friedman amp power output → Two Notes Torpedo Captor Speaker In jack
Nano Output 2R (capture output) → Friedman amp input jack
Two Notes Torpedo Captor line output → Nano Capture Input jack
Yes Sir, I had it wired that way.
