This would be incredibly useful for some use cases: Currently the crossover split does only have one frequency parameters and everything above gets send to path A and everything below to path b. I would like to be able to set two frequencies like a low and a high pass, what could result in a gap between the two resulting spectrums (and for an overlap too).
Example:
- Low Pass at 200 Hz = Path A gets everything below (and including) 200 Hz
- High Pass at 300 Hz = Path B gets everything above (and including) 300 Hz
Currently I need an extra EQ / Low High Pass block on one of the lanes after the split. For an overlapping crossover you would two extra blocks.
