Really want the option to connect a TRS Footswitch to turn the tuner on and off.
Would much prefer this over holding the tuner button on the quad cortex.
Yes - just remember that NDSP introduced a new feature in 2.3.0 update, where you can swap Tuner/Tap Tempo activation mode (double tap for Tuner and Long Press for Tap Tempo).
Has there been any update on this? Been trying to see if I can do it via the Midi jumper cable method and my Hotone Ampero ii EXP pedal with the toe switch but can’t seem to get it to work
You should be able to with the jumper hack and toe-switch, I’ve done it before.
Have you looked at the instructions on the QC wiki page?
i found them from another post you commented them on actually haha so thanks for providing them! Ended up switching to engaging the tuner when the pedals all the way down! Thanks again for your help!
